No headlights?!?
No headlights?!?
okay well i was on my way to the pizza place last night and i get there and i always leave my parking lights on when i go inside and i come back outside and get in and start it and i have no lights. just parking lights. my first thought was the fuse under the hood of the truck. nope that wasnt it. anybody have any ideas? its my daily driver that i drive in the morning to school and some help would be appreciated.
Don't take it to a stealership. They will charge you an arm and a leg for a new switch.
Go to a salvage yard. If they have any 1994-1998 Dodge Rams, the switch should work just fine in your 1995. Got a replacement for mine out of a 2002 (since I have a 2001), and it works great. Can't remember exactly how much it was, but it was well under $50. I want to say $35 or something around that.
If you can, find a salvage yard with a warranty policy. My local one has a standard 199 day warranty policy on all items unless otherwise noted.
www.rockauto.com has them for about $17 plus shipping. That's the best deal I've seen on them. They're almost $100 at my local parts store.
Hey Big96,
I have a 99 and I have the same problem. I am 95% sure mine is a short in the steering column. When I tilt the wheel all the way up, I have lights. When I tilt the wheel all the way down, no lights. I have found the "sweet spot" right in the middle where I have lights and I just drive it that way. If you have tilt, try turning the headlights on and slowly going through the full range of tilt. I have no idea how to fix my problem and don't feel brave enough to tear into the column. Good luck!
Trending Topics
Advance had what I needed for 22 bucks. Duralast and all ya gotta do is pull out the **** and put it in the switch part. Mine was stuck pretty good from me jackin around with it to get my lights to work before though lol.
Otherwise I think there's a purple wire on the steering column that goes into a blue holder ya might want to check out.
