Procomp programer+ death flash
#22
87 octane with torque management taken out
91 octane
93 octane
But before you do that:
Get this:
http://www.hughesengines.com/Index/p...z&partid=22220
AND THIS
http://www.hughesengines.com/Index/p...b&partid=23039
AND THIS:
Stant premium thermostat 180*: $4.97 PN: 45358 from www.rockauto.com
also:
With water neck gasket.
Any 180* thermostat will do. i got the jet performance one from summit. Get the all stainless steel ones.
You can just get the programmer and a 180* thermostat until you do the plenum repair. But if it is blown, then you will not get NEARLY enough out of the engine.
Best to get all the parts and spend the 450 to do it. Rockauto should be where you get all of your factory type sensors, gaskets, and parts. if it is not a PERFORMANCE part, get it from www.rockauto.com
