DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   Ok, I'm about to crazy! (https://dodgeforum.com/forum/2nd-gen-ram-tech/194055-ok-im-about-to-crazy.html)
tomwom Mar 20, 2009 04:30 PM
I have the ye olde belt whine.
I have replaced the tensioner, checked all the pulleys for noise or bad bearings, wire brushed all the pulleys, and put a new Dayco belt on, which by the way was on before I brushed the pulleys.
When I spray carb and choke cleaner on the belt when it's running, the noise instantly quits, but then returns a while later.
Is the Dayco belt a piece a junk? Should I go with a Gates belt?
Any help would be appreciated.
ophidia Mar 20, 2009 04:32 PM
I've always had good luck with Goodyear Gatorback belts.
TMS Bill Mar 20, 2009 04:50 PM
I use Gatorback. Get some belt dressing and see if a little shot shuts it up.
dblj16380 Mar 20, 2009 04:55 PM
Yeah, I would head down to the auto parts store and pick up some belt dressing. I think the can is about $5 but it works good. It stopped the squeak on my sister in laws Sunfire!
ophidia Mar 20, 2009 05:08 PM
Belt dressing didn't work on my truck, it still made noise.
Oh, wait, that was the alternator bearings.
n/m
Anyway, belt dressing will let you know if it is indeed the belt, but it wears off fast and the noise comes back. That's my experience anyway. I think the Gatorback for our trucks is about 30 bucks and they last nearly forever.
LadySashya Mar 20, 2009 05:33 PM
I've had intermittant belt noises too, but I noticed that it always acts up when the weather is especially humid, then gets better when it's not. My mechanic confirmed that his truck does this too. I don't know if that odd little fact will help you at all but hey, thought I'd share. Good luck!
zman17 Mar 20, 2009 06:23 PM
Make sure the belt tensioner spring is free. Take the belt off and work the tensioner back and forth, to obtain full travel. Spray some PB in where the spring is.
tomwom Mar 21, 2009 07:01 AM
Thanks for all the reply's, I'll try the Gatorback belt.
zman17 Mar 21, 2009 10:22 AM
The tensioner tends to get stuck at a certain point of tension over the years. If you don't make sure it travels to it's full extent, you will have the same prob in a short period of time , no matter what brand belt you use.
jreisman Mar 21, 2009 12:23 PM
you need a ac bypass pulley try omly spraying the clutch on your ac it will go away and come back 40 bucks at napa
© 2026 MH Sub I, LLC dba Internet Brands
