RPM's While Towing
I tow about 7k twice a month and was wondering were the rpm range should be. When I start out from a stop I get to the 4k rpm range in second gear until i get to my desired 65 mph on the freeway and then it shifts into third and i cruise along pretty well.
It goes up and down the mid 5-10% grades fine but occasionally there's the steeper 15% grade to which it kicks down to 2nd gear and runs 4k rpm's up the hill. Is this a normal thing for the amount of weight I'm pulling with a 97 dodge 1500 5.2L 4x4 sport. Based on the link below, the 4k rpm range is where my 5.2L engines power lies. http://www.rm-indy.com/Towing%20Tips.htm Sorry about the long post. Open to any opinions. |
When the TC is locked up goin 60MPH on a flat road, its around 2100RPM. Mine usually runs around 3000RPMs going up a hill in 2nd gear.
Well I'll see what happens this trip. Last time the truck over heated so since then I added a set of electric fans from a ford and new fan clutch and pulled the T-stat. I should be fine for this trip.
What Ford were the fans from? I'm interested in cheap electric fans! :D
To be honest I don't know. I've read here on the forum that 90-94 Ford Tarus had good reliable fans.
I went to a scrap yard with some knowledgeable people and told them what I wanted, "14'' dual electric fans" from any vehicle. He went to the pile he had and said here you go, they are from ford. I paid $30 for them and got a 30-day warranty as well. I tested to make sure they work then installed them. They run from 2 switches. |
Thanks!
you should put the thermostat back in. it helps keep your truck cool. without it it will stay cool for a while but once it warms up there is no way to regulate it and it will keep getting hotter.
Originally Posted by oops-sorry
(Post 1680238)
^no, no, no...
t-stat keeps an engine at hot temp (180-195) by partially closing and restricting or blocking coolant flow. no t-stat allows it to cool to its maximum potential. i think 4k is a little high. that seems likes its one gear too low. |
| All times are GMT -4. The time now is 03:35 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
