97 1500 Won't Start
I have a 97 ram 1500 with the 360. It will not start as of this morning. ran fine yesterday. no new gas recently. turns over and can hear the fuel pump charge. Any ideas....
Thanks Boss |
See if you're getting a spark and post back
+1 on checking for spark.
And, just because you can hear the pump running is not a 100 percent guarantee that it's actually pumping fuel, you need to test it with a pressure gauge to eliminate it as a problem. Check all the fuses in the dash and relays and fuses in the PDC (black box) under the hood also. |
Yup, def. sounds like a spark or fuel delivery issue. Like said above, test the spark first, pretty easy to do, and go from there.
| All times are GMT -4. The time now is 04:42 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
