Hub/Bearing
Old Sep 1, 2009 | 11:34 PM
atc250r's Avatar
atc250r
Default Hub/Bearing
My '97 1500 needs a right front axle seal as well as the right axle U-Joint. I'll be doing them both in the next couple weeks. Just wondering if it would be in my best interest to also replace the right bearing/hub assembly at the same time. The truck has 180,000 miles and the right hub was replaced once and now has about 87,000 miles on it. What do you figure? Do all 3 things since I'm there anyway?
Old Sep 2, 2009 | 02:57 AM
Sheriff420's Avatar
Sheriff420
if the bearing is good then leave it be. those things are 180$. check it by grabbing the wheel at 12 and 6 and pushing/pulling on the top and bottom. if there is any movement then it is bad. if there is any movement then you should check the ball joints before replacing the hub because they will allow the tire to move like a bad bearing would. after you pull the hub off spin the bearing to feel for it being too loose or tight and listen for any noise that would indicate that it was bad.
when you reassemble everything put antiseize on the contact points between the hub and knuckle and on the stub shaft splines and threads.
Old Sep 2, 2009 | 08:04 AM
olyelr's Avatar
olyelr
Sheriff hit the nail on the head.
To me, there is no sense in replacing a $200 bearing just because "I'm in there already" when its not even bad. That thing may last longer than the new one you replace it with. And its not really that big of a project to do later, just an hour or so if it goes well.
Now, I am all for preventative maintenance and such. For example, why I had my motor apart I was replacing stuff that wasn't broke (water pump, timing chain/gears, thermostat etc.), but that stuff was relatively cheap, and I hate doing motor work. But a bearing in good working condition with less than 100k miles, I vote leave it unless its wobbly.
Old Sep 2, 2009 | 10:33 AM
sungod's Avatar
sungod
I don't know if I would replace it, but I would coat it heavily with anti seize so that it wouldn't be as difficult to get off if you do really need to replace it later. You are not going to gain anything by replacing it now. It isn't difficult to replace if everything comes off easy.
Old Sep 2, 2009 | 10:46 PM
atc250r's Avatar
atc250r
Thanks for the advice, guys. If it has no play, and sounds/feels good, I'll leave it be.
