DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   99 Dodge won't stay running (https://dodgeforum.com/forum/2nd-gen-ram-tech/224038-99-dodge-wont-stay-running.html)
gvsu141 Dec 9, 2009 08:02 PM
I have a '99 Ram 1500 sport with the 360. Truck was running fine, I shut it off when I got home. I go to start it about 2-3 hours later, and it will start but will die as soon as I let off the gas. I can keep it running by giving it gas. There are so many possibilities that cross my mind, I don't know where to start.
It has been kinda slow to start sometimes, but it has done that since I have had the truck.
Also, it just started getting cold here in Michigan the last few days.
J415 Dec 9, 2009 08:06 PM
Do a search. There are hundreds of threads that will give you the answer.
dhvaughan Dec 9, 2009 08:17 PM
i'd guess weak battery is causing both problems. a weak battery screws up the reference signals to the IAC and TPS. also a bad battery sometimes won't accept a charge and come up to full 12 volt. jump it, charge it, or take the battery out and have it load tested.
gvsu141 Dec 9, 2009 08:18 PM
I have searched, I am guessing it is the IAC, but am not sure, thats why i am posting. The check engine light is not on, it comes on randomly when I am driving.
The battery was my first guess, but it is turning over fine, and volts checked out good, getting a good connection. I know batteries love to play tricks on you in the cold
Any help would be appreciated
95RAM360 Dec 9, 2009 09:26 PM
IAC could cause this problem. inspect, clean, return with details
dhvaughan Dec 9, 2009 10:16 PM
provided your battery is measuring 12volt when ignition off and 14+ when running, then it may be IAC only. but be aware that low battery voltage will cause false IAC problems.
i've not had much luck with cleaning IAC's. that only works when the pintle and/or well is all gunked up. unless you can see/scrap off gunk, just replace the stupid little thing. about $50.
Cali1500 Dec 9, 2009 10:27 PM
What the heck is an "IAC" and where is it located?
moparama Dec 9, 2009 11:04 PM
Just sell it!!! LOL
95RAM360 Dec 9, 2009 11:16 PM
Idle Air Control, and buy a haynes manual, it will tell you whatever you need to know
jjtroutbum Dec 9, 2009 11:18 PM
Idle air control sensor = IAC
© 2026 MH Sub I, LLC dba Internet Brands
