got my truck back from having gears put in :)
Old 12-11-2009, 12:55 AM
lb79theone's Avatar
lb79theone
lb79theone is offline
Location: Maine! ( GET A HOLD OF ME IF YOU WANT TO GET ME ON FACEBOOK.COM, AND CARDOMAIN.COM)
Good to hear guy! I want 4.56's now!
  #22
Old 12-11-2009, 05:22 PM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
Originally Posted by dakotas ram
cruising, with 31s and 3.55s, im right at 2k and 70mph
but did you have the speedometer corrected for different tire size?.... but that sounds kinda right...that would mean around 2100 rpm with factory 29" tires at 70mph...(just like my 35" and 4.56)
btw my factory size sized e250 van is at 2400 rpm at 70mph.....
if your down at like 1600 rpm at 70 your tranny has to be constantly shifting in and out of od and you likely never even reach od in the town/city roads....
  #23
Old 12-11-2009, 05:25 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by 99DRAM31887
ok guys im not trying to hyjack the thread, but how can you tell what gears you have i mean i know mine came out of the factory with 3.55's and i see ya'll talking about ya'lls rpms at certin speeds. Now is that at full throttle or just cruising because i went and test mine out and at 60 my rpms at a hair over 1500 and i have those 33's on there.
tell me what it is at 70 mph and I can tell you..
  #24
Old 12-11-2009, 07:30 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
You shouldn't be seeing 3K on a new set of gears for at least 500 miles. You want the pattern to wear in slowly and correctly. And don't tow or haul crap for the first 1000 miles.
  #25
Old 12-12-2009, 12:02 PM
lb79theone's Avatar
lb79theone
4.56's ok on the highway? Does it shifter harder too?
  #26
Old 12-12-2009, 12:10 PM
Augiedoggy's Avatar
Augiedoggy
4.56 gears with 35" tires work exactly the way factory gears work with smaller 29" tires...on our rams. both together = same final gear ratio and load on engine and tranny) the shiftpoints would all be the same as stock...(3.55 gears and bigger wheels is harder on the tranny and engine) If you have 33 inch tires 4.10 gears are ideal for highway....however if you only drove at highway speed and never towed 3.92 might gain you more mpg...but less power and less fun to drive.
contrary to what many believe depending on your driving habits your mpg can improve with 4.56 gears ..even on the highway since the tranny can stay in od with more ease ...when you have big tires and 3.55 gears most people are always into the gas pedal more trying to get power that isnt there anymore and they dump that wasted gas right out the exhaust...
I contribute my crappy mileage to bigg nobby mud tires and my driving habits.... I know I could do better.
  #27
Old 12-12-2009, 12:15 PM
lb79theone's Avatar
lb79theone
Ok. Good to know. Thank you.
  #28
Old 12-13-2009, 09:27 AM
engineblock's Avatar
engineblock
engineblock is offline
when im driving at 65 im at 2k already and i have stock gears.
  #29
Old 12-13-2009, 05:28 PM
Augiedoggy's Avatar
Augiedoggy
and if you were at 70 you would be at around 2100 prm... That is normal and exactly the same rpms at the same speeds I get with my 35" tires and 4.56 gears...
if you have something different than something is off from stock ratios...it could even be the speedo thats off
  #30
Old 12-13-2009, 08:18 PM
big.red.ram's Avatar
big.red.ram
big.red.ram is offline
wat are you running at 60? im running about 1900-2000. i dont think its only goin to go up 100 rpms at 70. that doesnt seem right since we have the same set up
Quick Reply: got my truck back from having gears put in :)
