Misfire on Cyl 8. Can't figure it out. help!
I have a Dodge Ram 1500 with a 360 in it. About 4 weeks ago the check engine light came on, even though i could not tell, the computer said it was throwin a misfire on cyl 8 code. So i took the spark plug out and it was covered in oil. So i replaced the plug and also noticed the wire was not on the distributer well so i thought that was the issue. About another week went by and the light came on again. i pulled the plug again and it was indeed covered in oil. So i replaced the distro cap and it went away for about another week and is now on again. It usually only kicks on while on the interstate at high RPMs. However I cannot detect the misfire because it seems to run well. Please, Any help that i can get will be greatly appreciated!
the oil is most likely form a blow plenum gasket,,,, replace that with the hughes kit and then do a full tune up if you havent
Do a compression test on all cylinders and report back here.
A blown plenum gasket wouldnt wet the spark plug with oil like the OP said. THe plug would burn it off, but would have a powder on it. |
Originally Posted by PurplDodge
(Post 1995994)
Oil could be leaking pass the intake valve seal or the guide. Does number 8 still misfire after you replace or clean the spark plug?
Originally Posted by Ramt0ugh85
(Post 1995920)
I have a Dodge Ram 1500 with a 360 in it. However I cannot detect the misfire because it seems to run well. Please, Any help that i can get will be greatly appreciated!
Now, the first thing that one needs to be aware of is, Dodge Magnum's are prone to misfire so much so that they put out a TSB to re-route the ignition wires to prevent that from happening. http://autorepair.about.com/cs/faqs/l/bl654h.htm Now, in your case, I recommend highly that you measure the compression in CLY No 8. IF- if it falls below 100- you've got a dead CYL that's not able to meet OEM spec for minimum compression for firing thus - no detonation, thus the oily / wet with fuel - plug due to it NOT being burned off. I had a dead CYL due to bad heads- crack in No 8 valve seat coupled with a bad valve that would not seat 100% thus - 60-90 on the compression stroke vs 160 on the others. Plug was somewhat oily but not excessive. So, I think, you may either have some blow by at the oil ring that is either snuffing / fouling the plug or, no compression due to bad ring / blow by or, perhaps a valve / head issue. Try rewiring it first and TEST IF - if the problem persists: COMPRESSION TEST CLY No 8. START there first. CM |
Here is a very complete list of Technical Service Bulletins (TSB's)
If you click this link, then scroll down to the first BIG RED LETTERSthen you will see the V6/V8 TSB for rerouting the sparkplug wires.
http://dodgeram.org/tech/gas/Trouble/Problems.htm LOTS of really good reading on all the rest of this link as well... Shows how to test your engine for a plenum gasket leak with a pressure/vacuum gauge so you can either verify or eliminate that potential problem without ripping into your engine. Tom |
Could a cracked head cause oil to mix with your antifreeze? Or could the plenum leak cause that?
Awesome as usual cm, i never knew that sparkplug wires touching eachother would cause problems. ty!
Originally Posted by cmckenna
(Post 1996539)
Misfires can be caused by a number of things, one being a fouled plug. If it's just one CYL, it's most likely No 8 because, that's usually the first CYL to drop compression first due to spent rings, valvetrain issue etc. Dodge Magnum heads are very well known for dry cracks at the valve seat and spark hole to valve seat area.
Originally Posted by zje400ex
(Post 1997238)
NO: if it's a dry crack in which case, the crack is isolated from coolant passages. The plenum leak only affects vacuum- it's isolated from coolant as it's part of the INTAKE. However, what can happen with that is, since it is a vac leak, it will suck engine oil INTO / THROUGH the leaking / failed gasket and this oil, is sucked into the combustion chamber. At this point, it's either burned off or it's not. In the case where it's a gross-leaker, the amount of oil is far too great to be burned off thus inducing failure of spark due to fouling of the plugs. CM |
| All times are GMT -4. The time now is 06:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
