DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   High Beam indicator won't light (https://dodgeforum.com/forum/2nd-gen-ram-tech/241500-high-beam-indicator-wont-light.html)
vfly172 Apr 12, 2010 09:09 AM
I replaced the bulb, and it still isnt working. I really depend on it because I have HIDs and don't want to be running the highs. Any ideas where to go from here?
97r/tram Apr 12, 2010 02:00 PM
It's probably the bulb behind the dash is blown.
vfly172 Apr 12, 2010 08:29 PM
I went to the local dodge dealership and purchased a new bulb assembly. Still isnt working. Should i get another and try that? the one i bought looks like the filament inside is fine though.
HeyYou Apr 12, 2010 08:51 PM
While you are in there, turn on your high beams, and see if you are getting power to the bulb, if so, check the ground as well. If you have both of those.... bad bulb.
lastrights Apr 12, 2010 08:52 PM
i would check out the fuses under the hood, just found out mine was a blown
© 2026 MH Sub I, LLC dba Internet Brands
