how do i adjust parking brake?
Hey everybody. I think my parking brake needs tightened up. It's to the point where it won't hold on a hill like at a boat ramp, even though I know the tranny will hold the truck there while in park...maybe. I like to set it when on the ramp so that when i go to shift out of park into drive or reverse, it keeps the pressure off of the tranny and I feel it makes for a smoother shift into drive. Also another reason why i think it needs adjusted is when in neutral, the parking brake won't hold with the boat behnd on a hill. So how should I go about adjusting it? thanks guys!!
That can mean two things, the brakes in the rear have shattered " rear brakes very rarely wear out" or it needs to be tightened up which you can do by adjusting the linkage right infront of the drivers side rear tire, i cant remember the socket size but once you see it, you will kinda know how to tighten it up.
Thats half the reason of a parking brake, you dont want the extra strain on the tranny when your parked while your towing something and the parking brake should easily hold a boat,
My suggestion since you are towing a boat would be to spend a little money and get new shoes and springs for the rear brakes there pretty cheap and give some piece of mind and if you want to be spendy and get bigger rear cylinders for $20 bucks and be really happy
Trending Topics
i set my parking brake on the boat ramp and it holds fine. i don't like to let it roll to the point where the transmission holds it. i've seen vehicles get stuck in park, where you couldn't shift it. i don't want to be in that position at a busy boat ramp.
I'm sure it's happened, but I've never personally seen one stuck. Less likely if they set the brake before putting it in park. But over the years I've have seen more than one turn into a crappy submarine and end up a big pile of salvage metal by just using the brake.
