Plenum Repair Materials
Old 05-24-2010, 05:50 PM
Nando Vazquez's Avatar
Nando Vazquez
Nando Vazquez is offline
Default Plenum Repair Materials
Im planning on ordering all the things I need to repair the plenum plate.
Here is everything I have and the prices. Does this sound alright or am I missing something.
Plenum KitsAPS $84
Hughes$86
Intake Gaskets and Bolts APS$55
Huges $45
180 Thermostat Hughes $12
Cap & RotorAutozone $35
Spark Plugs Duralast $25
Bosche $35
Ignition CoilAccel $63
ShippingAPS $20
CoolantAutozone $20
Injector O-rings $5
Throttle Body Gasket $5
Cold Air Intake Gasket $5
Intake Bolts$15
Is there anything else I would need, or that you guys would recommend?
Old 05-24-2010, 06:31 PM
Salex007's Avatar
Salex007
Salex007 is offline
might as well as do the timing chain as well since your that far along with a water pump
Old 05-24-2010, 08:01 PM
94Beater's Avatar
94Beater
94Beater is offline
Forget ignition coil.
They are all junk - just keep the stock and you'll have no issues.
I went through 3 brand name new coils each one took a dump after few months.
Stock coil never gave me any issues.
Old 05-24-2010, 11:27 PM
Nando Vazquez
I just recently replaced the water pump, but I dont think I can replace the timing chain, i dont know how to align it properly.
Old 05-24-2010, 11:34 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,385 Likes on 3,125 Posts
it easy, just turn the distributor so it is pointing to number one cylinder, and then line up the marks on the gears when you install them. Getting to it is the fun part, actually doing it is simple.
Old 05-25-2010, 01:03 AM
truegent81's Avatar
truegent81
truegent81 is offline
i know DV did timing chain. it would be awesome to do if you know how. only a couple of bolts after doing plenum. search for timing chain, should have some pics.
just wondering why you have intake bolts listed three times? is that just for bolts and no gasket from AZ? make sure to double check on the amount of fluids you will need to finish the job i.e coolant, oil, etc.
is ignition coil by accel just the distributor assembly?
Old 05-27-2010, 01:34 PM
Nando Vazquez
The last set of bolts at the bottle of the list I forgot to take off. And Im not getting ignition coil. what does everyone recommend the Hughes or APS
Old 05-27-2010, 08:23 PM
gdamtbnms's Avatar
gdamtbnms
gdamtbnms is offline
dont forget lock tight... my plenum kit came with new instructions to use ultra copper gasket sealer for the plenum gaskit so you need that as well.
i didnt take off my injectors or the throttle body so unless you just want new gaskits for that ok but you dont have to take them off
you might want to make sure you have a torque wrench you need to torque them 3 times 24/48/86 INCH lbs of torque... i say INCH because i snapped a bolt into the hole of my intake trying to torque them down to FOOT lbs of torque lol wasted a whole day trying to get it back out
good luck its not that hard a job.. i got mine from abs cant compare but it was a good product
Old 06-01-2010, 03:34 PM
truegent81's Avatar
truegent81
so i was about to purchase a new water pump from moparonlineparts.com but ive noticed on some parts it states "w 8.0L" or "w/o 8.0L". what is the 8.0L they are talking about? i think it is the v10 but on some parts the only option is 8.0L...just double checking before i order it.
for example: why would a termostat housing for a ram with a 8.0l be $100 but w/o a 8.0L it is $6? TIA
Old 06-01-2010, 04:08 PM
Nando Vazquez
yeah i think that refers to the V-10 engine. Not completely sure.
Quick Reply: Plenum Repair Materials
