Does the "Return to stock" count as one of your 3 tunes?
Or does it have a slot saved for the stock tune, and you can program 3 others. I just want to ensure that I can't erase my stock tune already on there.
Nope, its just the setup that your truck had on before you installed your tunes. You should have three tunes, then return to stock
yeah, i figured that was the case. I just needed to make sure.
--Dan
BTW, BIG difference between the 93 and 91 octane tune. Ran like a top with 91 octane on the higher tune, but with the help of the fitch fuel catalyst. In my mind it is worth the money so you can improve the quality if your gas and make your engine run cleaner.
No wonder why my spark plugs were spotless When I did the project last weekend. I use valero gas.
