Truck won't shut off
This morning I jumped in the truck and it started fine. Ran to the store, and when I came out the battery was dead (only in there for about 5 minutes). Had someone jump me, and went to the parts store. They checked the battery and told me it was bad. So I bought a new one (never turned off the truck). Got home, turned the key back and pulled it out of the ignition, went to get out of the truck and that's when I realized it was still running! No key in it, in the OFF position, truck still running. Had to pull the Automatic Shutdown Relay to get it to shut off, and then disconnected my already dead battery, because the dash lights where still on.
Oh, and the steering wheel still moves freely, with the key in the OFF position... |
do you have a remote start installed? maybe faulty?? i really have no idea
sound like your ignition cylinder is at fault if it's not locking the wheel either... can you shift out of park when it's off also?
Only when I press the brake.
Originally Posted by cruizer
(Post 2194770)
yup you must have something broken or unhooked in there, your key isn't actually turning anything when you turn it off. From the sounds of things I'm surprised it'll still start it... Does it still shut off your radio etc.?
It didn't shut off any of the electronics, no. I also misinterpreted, I could not take it out of park when the key was in the off ignition, even though the truck was still running. I replaced the ignition lock cylinder, and it turns on and shuts off now. But the steering wheel still doesn't lock.
My 2005 dodge won't shut off either checked the ignition changed it and still having problems the brake light stay on and abs light stays on when it's shut off and keys out
Originally Posted by Dave mccurry
(Post 3243320)
Also, this thread is five years old....... |
How come threads stay open for years with no activity? This is the only forum that i have seen this on. Usually will get closed after about 6 months with no activity.
| All times are GMT -4. The time now is 12:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
