Magnaflow Hi Flow Cat/Straight Pipe Q's
Old Sep 13, 2010 | 02:10 PM
LegendKiller89's Avatar
LegendKiller89
Default Magnaflow Hi Flow Cat/Straight Pipe Q's
Okie dokie, so after the truck is painted and stuff. The next two things on the agenda will be to take the 20% tint off and put 5% on the truck, The other is to re-do the exhaust.
So I am going to buy a Magnaflow Hi-Flow Cat. And then I WAS thinking of putting in a Y then dual straight out to a 45 behind each tire.
However.
I was just curious what would be the difference in sound from doing the setup I just listed versus doing TWO Hi-Flow Cat's and straight pipes off each cat? Will there be a large noticeable difference in sound?
I would be running 2.50'' exhaust to 4'' tips.
Old Sep 13, 2010 | 02:23 PM
pcfixerpro's Avatar
pcfixerpro
However.
The second option is more of a pain, more money, for basically the same result. You might want to consider adding a muffler too. I personally prefer exhaust tone over noise. You can always do your first suggestion and add a muffler if you don't like it later on. Just something to consider. Otherwise it sounds like your on the right track.
Old Sep 13, 2010 | 03:02 PM
CSXfan's Avatar
CSXfan
No real difference except money, and you might have to get a little creative with the o2 sensors. And like pcfixerpro said, I'd get a muffler, even if it's just a glasspack or something. I had a single straight pipe and a high flow cat on my truck for a week and hated it. The drone inside the cab was unbearable and it didn't sound good outside. The cops weren't a fan of it either.
Old Sep 13, 2010 | 03:04 PM
lastrights's Avatar
lastrights
ya it will be alot louder i would put out the back or at a angle, to close to the cab your going to get annoyed sometimes
