I'm sorry if I ruffled a few feathres with this thred. That was the last thing I wantend to do. Just wanted a few suggestions or answersers. Will not do it again or you can barr me. Garry
You should only have one that matters on a 98, and that one is back on the rear differential. Right up on top. Check the connector, and make sure it is clean, and tight.
Originally Posted by zman17
The sensor is located on the driver side of the tranny right in front/above the tranny mount and skid plate. You also see the two vac lines for the cad right there.
Originally Posted by OhioChuck
As zman17 said, it's on the driver side of the transmission near the back. My truck had the same code last summer and I replaced that sensor - new one was under $20 at NAPA. Make sure you have the new one handy before removing the old one because it starts barfing out tranny fluid as soon as you remove it. Very easy to change and gets rid of your P0720 code.
p0720 is for the speed sensor that is in the OD unit of the auto tranny. I know this because it is one of the codes I now have because I have swapped in a manual trans and am still using the auto computer.
Just my .02. But the code is for a output speed sensor. NOT a vehicle speed sensor. Big difference. rear diff has a VSS on it(just like the ABS/speed sensors on the front wheels) . A output speed sensor picks up its signal on either the output of the trans and/or input of the t-case(4wd). You dont have a scanner available? Lots of tests can be done to ensure that the sensor is bad or not. The code is for the signal the computer gets from the sensor. DOES NOT mean the sensor is bad. I've fixed this issue(CEL) without changing the sensor, it's not always the problem. JD
I didn't mean too **** anyone off I was just pissed off about the truck. I apoliige to anyone i may have offenneded. Just had a bad day I guess. please forgive me. Anyway I put the old stock air cleaner on it I had a 14x3 and it did nothing I'm thinkink maybe the map sensor or something like that is going on to make it stall like that.
