door sagging
anybody have their driver door or passenger door sag on them? my driver door is sagging a bit, nothing to be hugely worried about, but I am curious if its possible to adjust it back to where everything lines up just right as if it were from factory. I don't know how this would be done. thanks guys
The doors are sagging do to worn out hinge pins and bushings, You can try to adjust them back to stock by realigning the hinges but the best way to fix this problem is to get a hinge pin and bushing repair kit. Sorry i don't have a link to any sites at this time maybe some one else does.
yup i have the same problem, but my doors still close fine so i say screw it.....but you can see near the bootom of door the pin inside will be bobbing up and down if you move the door...thats where the problem lies.....common problem.
if your door don't drop too much i would not worry about it. i replaced the pins and bushings on my 91 but they dropped a lot. the pins and bushings for my 91 was only $10 for the 1 side.
ok thanks guys. sounds like a simple fix. Yeah i'm not too worried about it, it still shuts fine but you can tell its out of alignment. maybe if I get a notion to fix something, I'll fix that
