95 dodge ram 5.2L how to set the timing?
Old 02-09-2011, 01:10 PM
suburban99's Avatar
suburban99
suburban99 is offline
Default 95 dodge ram 5.2L how to set the timing?
Hey all, son's truck...idles good but not much power... suspect timng? no codes. What do you think?
Old 02-09-2011, 01:31 PM
bigdaddyjr's Avatar
bigdaddyjr
bigdaddyjr is offline
have you tried a tune up plugs wires cap rotor? did this come on all of a sudden or over time
Old 02-09-2011, 04:13 PM
suburban99's Avatar
suburban99
Plugs yes, wires and cap are coming...truck has been sitting about 2 years...inside of cap has white stuff attached to the pins...corrosion maybe..tried to clean it but no avail. #8 plug completely fouled and not firing. Wires are suspect. Idles amazingly well.
Old 02-09-2011, 04:24 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
Timing is set by the computer.
Old 02-09-2011, 04:55 PM
Annihilator_X9's Avatar
Annihilator_X9
Annihilator_X9 is offline
Have you checked the Plenum? Fuel Pressure?
Old 02-09-2011, 08:19 PM
suburban99's Avatar
suburban99
Plenum gaskets replaced, intake manifold gaskets replaced. throttle body cleaned.
Never drove truck much until now as he has just got a learners license. Got a new cap, rotor, and wires coming. Idles nice, runs like crap under load. We rebuilt the 45rh as it was pooched when we bought it. #8 plug very fouled...I wonder if it has a bad valve...may need to do a compressor test. Has no error codes in computer.
Old 02-09-2011, 08:28 PM
PurplDodge's Avatar
PurplDodge
Catalytic Converter and front O2 sensor.
Old 02-15-2011, 08:55 PM
suburban99's Avatar
suburban99
Gutted cat and new o2 sensor. Also new plugs, wires, and cap.
What is the sensor that is near the distributor screwed into the transmission right at the top, it appears to be broken...crankshaft position sensor?
Old 02-15-2011, 09:08 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Oil pressure sending unit.
Old 02-15-2011, 09:13 PM
polish pete's Avatar
polish pete
polish pete is offline
wrong, truck still has a distributor not coil over plug ignition, if you want you can loosen the dizzy and rotate it advance or retard, but be careful you should really have a timing light. do your tune up make sure your 02 sensors are functioning correctly and check for a plenum leak.
Quick Reply: 95 dodge ram 5.2L how to set the timing?
