transmission shifts at high rpm?
I have a 2000 dodgeram1500, 5.9 litter sport..... My first to second gear shifts at 3000 rpm, second to third gear shifts at a normal 2000 rpm and from third to forth gear also shifts at a high rpm.... My check engine light is on so i checked the codes and it came up with, p-0500, p-0463. So far i replaced the transmission speed sensor, and the throttle valve cable. And still the same problem, can anyone please offer me some advice...thank you.(i know the p-0463 has to do with the speedometer)
