Trans doesn't want to shift.
I just purchased a 2000 ram 1500 A/T the truck doesn't want to shift gears. It sticks in first until I let off the gas then it shifts. In 2nd it really doesn't want to shift and i have to do the gas pedal thing several times to get it to shift into 3rd. I replaced the output shaft sensor but that did nothing. Any ideas??
bad trans not engaging...shift control module...worn valves? could be lots of things.
Pulled a governor pressure sensor code so i picked up a sensor and a selonoid and a filter kit I'll install tomorrow after the rain stops.
Perhaps you will get more support if this was in the Ram section where it belongs. I will have it moved for you.
it has been moved
1 Attachment(s)
Originally Posted by gman13514
(Post 2620110)
And if you have the time, read this thread please ;) https://dodgeforum.com/forum/2nd-gen...e-tragedy.html Attachment 61393 |
Installed the sensor and selonoid. the fluid was dark but not all burned up and the only thing in the pan was themetal around the magnet. Took it for a spin and it shifts great. Thanks for all the help!
Cool beans ! ;)
| All times are GMT -4. The time now is 04:33 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
