I want to redo my exhaust and what set up should I run
Old 10-28-2011, 10:33 PM
CPTAFW163's Avatar
CPTAFW163
CPTAFW163 is offline
JBA headers and a new y-pipe. You can just have an exhaust shop make a y-pipe for you cheaper than the jegs.
THat will actually give you a performance gain, and will also cost about 800-900 bucks total (with labor).
Old 10-28-2011, 11:33 PM
mgaither0's Avatar
mgaither0
mgaither0 is offline
Originally Posted by J415
To the OP. Is the muffler single in dual out? If so, I'd be more then happy to trade you my super 40 for you super turbo. I always loved the sound of the super turbo's mellow tone.
Its single inlet single outlet.
Old 10-29-2011, 03:10 AM
stewie01's Avatar
stewie01
stewie01 is offline
Originally Posted by gdstock
When you select 1999 Dodge, Jegs website show only Van when you look for 1500. Not sure 2500 would work...
Stewie, can you post the link or part number?
Thanks.
http://www.jegs.com/i/JEGS-Performan...oductId=758633
It shows year models '94-'99. I'm not sure if it'll work for the '00 and '01 or not. This is the only one they show for Dodge.
Old 10-29-2011, 03:55 AM
96magnumram's Avatar
96magnumram
96magnumram is offline
I run a Dynomax Race Bullet...the 16 inch long version...
Old 10-29-2011, 04:18 AM
joekool4's Avatar
joekool4
joekool4 is offline
true duals! and small(er) diameter straight pipes (will keep low end). and they wont be toooo loud.
Old 10-29-2011, 09:35 AM
lastrights's Avatar
lastrights
lastrights is offline
Get a single chamber muffler with high flow cat , also don't go to small on pipes it will sound like ****
Old 10-29-2011, 02:03 PM
99dodge318's Avatar
99dodge318
99dodge318 is offline
I wouldnt run true duals, your motor needs a little bit of back pressure to run right, also you would have to figure out something for your o2 sensors.
Old 10-29-2011, 03:01 PM
stewie01's Avatar
stewie01
stewie01 is offline
How would true dual's with cat's or without and whatever muffler of choice on say 2.5" pipe hurt the back pressure?
O2 Sensor may be a little more fun to figure out, but I'm sure someone has, I KNOW he's not the first person to think true dual's on a 2nd Gen Ram, or any Ram for that matter.
Old 10-29-2011, 03:05 PM
stewie01's Avatar
stewie01
stewie01 is offline
I used to drive a 1998 Chevy K1500 with a V8 305, stock air cleaner with K&N Filter (box with filter is setup on the passenger fender with pipe going to intake) no catalytic converter, a magnaflow muffler (not sure what series) and it was single in dual out and it sounded GREAT and had lot's of power. I know that was a Chevy and not a Ram but I would think you'd get similar results with any healthy engine.
But that setup was not true dual exhaust, just dual from the muffler back.
Old 10-29-2011, 03:20 PM
S S0DEN's Avatar
S S0DEN
S S0DEN is offline
I run SLP Headers, high flow Y pipe, gutted cat, FlowMaster cat back (dual outlet, rear exit). No engine light at all. Sounds great and ran great, the 360 is being rebuilt as we speak and changing the stock heads (cracked) with some Edelbrock Aluminium heads, RV cam and a little intake work.
Quick Reply: I want to redo my exhaust and what set up should I run
