I'm not sure if you can hear the crackling noise when turning wheel. Clockspring was replaced. Horn airbag and cruise now work. But as you notice in other video, the orange gear indicator has slow reaction.
Has anyone watched those videos?
Who replaced the clockspring?
The gear indicator is most likely out of adjustment. The drop down panel under the wheel just needs pulled off and you will find the white adjustment thinger attached to the column... Take a good look at how it works and make adjustments as needed.
. I purchased clockspring from advance. I had a local frame shopshop do alignment and install clockspring.
It turns easier to the right. But the alignment is good!
I would have a chat with the folks that did the install, and see what they have to say.
Yes I am definitely calling first thing Monday after today's episodes. I was turning onto a busy highway and it seemed as if it locked up I yanked it hard to keep from making a 360 into the field and something broke I can feel it moving around when turning. The horn and cruise control still work.
