vacuum leak @ hvac controls?
Old 12-01-2011, 12:28 AM
cutthroatxxx's Avatar
cutthroatxxx
cutthroatxxx is offline
Huh...see I can hear it coming from there but nothing is cracked its driving me nuts
Old 12-01-2011, 11:46 AM
cutthroatxxx
Ok so I took the vacumm harness off&its not a leak I hear its a sucking theres a black hose&its pulling vacuum none of the others are.Any ideas?
Old 12-01-2011, 12:10 PM
cutthroatxxx
Ok does anyone know how to tell if the 'Im guessing its a actuator for the flap door'is bad If I push the lever by hand it will go to vents,Ive also noticed I have air blowing out@feet before I thought it was just dash,
Old 12-03-2011, 11:54 AM
cutthroatxxx
Nobody has any ideas?Ive looked@all of the vac lines&they all seem fine.But the one I spoke of earlier sucks even when the control **** is in the off position.When I rev the motor it will suck harder.This is driving me nuts.
Old 12-03-2011, 03:20 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,385 Likes on 3,125 Posts
If you have insufficient vacuum, (like a leak at the control head would give you) the doors won't work right. Need to address that problem first. If it is the actual control that's leaking, you have to replace the whole thing. It isn't serviceable. (at least, not according to dodge....)
Old 12-03-2011, 05:23 PM
cutthroatxxx
I dont think its the control itself like I said when I took the vacuum harness off the one line is constantly sucking.So if its on&I out it in the off position,the circulate or vents it will suck.If its on the defrost, dash or floor it works fine.I replaced tons of vacuum lines nada Im guessing it's the blend door actuator.but I have no idea how to check it.Id hate to take it to a shop for this .
Old 12-03-2011, 07:46 PM
gdstock's Avatar
gdstock
gdstock is offline
As Hey Yous tated, parts manual in the FAW/DIY section.
Old 12-03-2011, 07:53 PM
cutthroatxxx
How do I find the faq diy page?
Old 12-03-2011, 08:00 PM
gdstock's Avatar
gdstock
gdstock is offline
Topofthe pagewhereyoupostedyourthread.
Here it is: 2nd Gen Ram FAQs, DIYs & How To's
There is also a service manual that you can download there as well. It can help with the problem.
Old 12-03-2011, 08:43 PM
cutthroatxxx
I cant seem to find nothing on how to check the actuator for the blend door.
Quick Reply: vacuum leak @ hvac controls?
