DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   I can't drive 55 (https://dodgeforum.com/forum/2nd-gen-ram-tech/328129-i-cant-drive-55-a.html)
kmart616 Jun 8, 2012 11:30 PM
I can't drive 55
Hello Everyone!
Heres what's goin on. 94 1500 Magnum. When you get up to 55mph and try and hold that speed it starts buckin, can't tell if it's the motor or transmission. Now, if it's under a load like up a hill or accelerating it will not duplicate, but on a decline or trying to hold 55 on a level roadway it will shimmy and fight me. you can play with the throttle by letting off a little and find a sweet spot but is super irritating.
-thank you for any and all input, Kevin
mccart Jun 8, 2012 11:42 PM
Would it possibly be tranny trying to shift all the time? I'm not sure but sounds like a possibility, that your rpms are right in between 3rd and overdrive and it can't decide which to go into
stewie01 Jun 9, 2012 08:37 AM
Misfire?
kmart616 Jun 9, 2012 10:29 AM
i would like to think it is fuel related. possibly a t.p.s or an injector. the transmission is goin on me. not liking 1st or 2nd gear. but like i said I can't tell. hopin someone has experienced the same prob. before.
Problems I have already had
- intake plenum - repaired
- head job 6 months later
- fuel pump - scotched locked a 2001 fuel pump into the harness
- overheated motor - bad sensor - actually locked motor up but was able to free it loose and subsequent head job followed
- broke cardinal rule - changed tranny fluid well after 60k
Thanks, -Kevin
kmart616 Jun 9, 2012 10:32 AM
One last thing I forgot to mention. the intake tap off the exhaust manifold does not have a good seal and also a couple pin holes on the dump before the cat(which is hollowed);)
HeyYou Jun 9, 2012 10:42 AM
Sounds like misfire. When was the last time you checked your assorted ignition parts? (cap, rotor, wires, plugs)
gdstock Jun 9, 2012 12:13 PM
+1 on ignition parts.
And WHAT does "tap off the exhaust manifold does not have a good seal" meanin English?
HeyYou Jun 9, 2012 01:11 PM
My guess is the egr tube.
merc225hp Jun 9, 2012 01:24 PM
You seized the motor by over heating it, I would start with a comp test and see what's up.
gdstock Jun 9, 2012 01:55 PM
+1. When engine gets overheated, something usualy fails. When it locks up it is usually the result of whatever failed, warped, etc.
© 2026 MH Sub I, LLC dba Internet Brands
