2001 Dodge RAM 1500 Gasping & Stalling
My 5.9 RAM started the occasional "gasping"... not sure exactly how to explain it other than pushing the gas pedal and having no power, some knocking and no acceleration. Pop it in neutral, shut the engine off, restart it and I can continue on my way without a problem for a while. Sometimes it happens while idling and it stalls. Same fix - shut it off, restart it and everything is cool for a while.
Been meaning to check for leaks on the intake manifold, just no time lately. Already replaced the distributor cap. The only code it's showing is one for an evaporator leak (forget the number but it's the one the says to try replacing the gas cap). Tried that too with no luck. Can't find any cracked vacum lines. There's no consistency about when it happens. Sometimes happens when it's damp and raining, other times when it's hot and sunny out. Sometimes after and hour or so of driving, sometimes after it's been running for only a few minutes. The truck only has 60,000 miles and was never beat on. If anyone has a similar problem with a known fix and can save me some time in the garage I'd really appreciate any suggestions. |
is it a case where the engine only revs up to a certain point, like 2000 rpm or 2500 rpm and then no farther --- cat is clogged up.
other common issues could be bad TPS (throttle position sensor). low fuel pressure/bad fuel pump (check pressure with a rented gauge from local parts store).
that is straightens out on restart leans toward something electronic, or sensor related. |
TPS sounds promising. Cheap and easy to get to. Thanks.
Mine has done the same thing for a few years now. It only did it in the summer, so I figured coil. New coil....Still happens
Originally Posted by pseudonoise
(Post 3021192)
when I have to restart it the engine races and it's hard to stop
I accidentally fixed this stalling problem when trying to fix an evap leak code. At least it appears that I fixed it. The charcoal canisters under the bed of the truck had some cross over pipes that were really cracked. I replaced them and the stalling went away. Going on about 1 month now Still have that P0455 evap leak code but I think that may be an air pump.
For the cracked hoses I found this video pretty handy: |
(Post 3021192)
(Post 3021192)
