has anyone here on the site heard of a shift computer underneath your passenger seat
hey all I was just wondering if anybody heard of a shift computer that supposedly controls the transmission under your passenger seat? I have a 98 Dodge 2500 having shift problems of don't want to shift in overdrive but I could shift manually from first to second but nothing from 2nd to 3rd.seems in limp mode, but not setting any codes. Speedo is going bonkers too, Have replaced the output speed sensor on tranny but didn't. Fix. Last year put new sensor on diff,culd it be bad again?
on
Welcome to DF
No there no control under the passenger seat that controls the transmission. The Powertrain Controller controls the transmission for overdrive. Do you have a 5.9L gas engine, 8.0 V10 or a 5.9 diesel engine in your 2500 truck. Next question, do you have a speed sensor on the transmission? That is not the same as a output speed sensor. Also rear sensor on the differential is for the ABS, is the ABS lamp on? Because if it is the tone wheel on the carrier could be missing or bent tooth. If the transmission isn't shifting when you move the lever to drive, Then I would say the problem is in the valve body. When was the last time the transmission was serviced?
on
Trending Topics
