what is this in my trans pan???? please help!
2 Attachment(s)
changing my solenoids and other items due to a hesitation between first and second gear shifting when over normal throttle and found this in my trans pan along with a lot of fine metal shavings on the magnet... what is this and what do i do???? (Doesn't look like it broke off anything)
thanks |
its the rear band anchor... how the hell do I put this back?
http://www.transmissioncenter.net/OLD_IDENTIFY.jpg |
Back off the adjuster enough so you can reinstert things. Should be a strut in there somewhere as well.
Start saving for a rebuild.
(Post 3166009)
If you have metal shavings time to start thinking about a rebuild. Shavings is a sure sign it will go out on you in the near future. Sorry man.
Cant help you on dropping the valve body, not experienced enough with transmissions to know, hopefully someone will have the answer. |
Shouldn't have to drop the valve body.
(Post 3166091)
+1, and yes to start saving money. |
-2 on should not have to drop the VB +1 from experience you DO have to drop the VB.
