Help ?????
Hi i have a 1999 ram 1500 have replased cam/crank/oil/o2 senser's dis cap & rotor now top radeator hose get hot and truck dies show's nobus played with plug on pcm it started and a lot of smoke cam out of tail pipe shut's down going down hiway at 60 not good thank's for some help
Moving to the correct section. Welcome to the forum. That's the longest run on sentence. Ever.
What color smoke?
Sounds like bad PCM.. |
(Post 3245498)
What color smoke?
Originally Posted by rod knepper
(Post 3245785)
blue and white
Blue is oil, white is coolant. (or, just condensation burning off, how much you get makes a difference) Oil is more than likely valve seals.
Losing any coolant? Oil?? |
Originally Posted by heyyou
(Post 3245818)
blue is oil, white is coolant. (or, just condensation burning off, how much you get makes a difference) oil is more than likely valve seals.
Check fuel pressure.
The white smoke isn't a good sign...... |
