whitesquirrel45 |
06-20-2015 01:49 PM |
Stuttering, loss of power, fuel or other
I have a 99 ram 1500 5.2. I got this truck a year ago and it ran like poop. So I did I tune up; cap, rotor, plugs, and wires. That was last June and afterwards it ran great. Fast forward to Feb/march. I found this forum and I did my water pump, plenum, and timing set. I cleaned my IAC and replaced valve cover gaskets at the same time. About a month ago it started running like poo again. Stalling, spitting, sputtering. When I first start the truck, its fine for a few seconds and then it starts. It spits and sputters, I hit the gas its ok for a minute and back to crap. When I take off it wants to die so I floor it and the truck comes out of it. About 40-50 mph it wants to do this all again so I put it in neutral and pump the gas. The rpms increase without any problems. 55-60 mph with the cruise set the truck develops the same issues. I replaced the plugs about 2 weeks ago and this didn't help. The old plugs looked as if the truck was running lean.
The temp seems to be low also. Running down the road it looks like its a little more than a 1/3 of the way up the gauge. I replaced the t stat also along with the temp sensor next to it. When I turn the truck off at a gas station and get back in to start it the gauge reads closer to 210.
I'm in the process of changing my o2 sensors, big PITA, to see if this will help my stalling issue. Im going to test my fuel pressure later today to eliminate that as a problem. I don't want to just throw parts at it until its fixed, please help!
