A/C woes
Ok, here's the story. tracked my a/c leak to the infamous inside the heater box.. While I was waiting to get to that repair my a/c clutch went. I got a used compressor and turned out to be bad. kept blowing fuses. got a second used compressor and now it won't work either. I vacuumed down the system, put 2lbs of refrigerant in and have power to the compressor. The coil is magnetized to. But the compressor will not engage. Any suggestions? Did I get another bad compressor? Thanks
Originally Posted by RH31379
(Post 3260578)
There is a simple fix. I had the same problem. Just remove the center nut on the clutch, then carefully remove the outer disc, watch for the tiny washer shims that you dont loose any. Remove one of the shims and reassemble. Should work now. If not remove another shim. |
Thanks, I'll give that a try. If it works tho should I be prepared for it to wear out again and need to be replaced?
You should be fine for quite a long time if it works. If not remove another shim. If that wears out then get a new clutch on ebay. They are only about $90.
