New timing chain slack, different chain?
So I have a Comp Cams timing chain, brand new, just bought. It has a lot of slack in the chain (http://tinypic.com/r/2zsslsh/9). I know the Mopar Performance chains have little to no slack but the dots are wrong on the gears. Maybe the solution is to order a chain tensioner but I don't like how the chain wears the plastic tension bars and plastic grit gets into the oil.
I need help ASAP. Trying to get this back together as soon as possible. |
I went with the Comp Cams chain and mine had little to no slack, think you might have got a bad one. I'd exchange it.
The Cloyes I put on mine was snug... that's about half of what my original looked like when it came off.
Originally Posted by jsmith1969
(Post 3272815)
Originally Posted by Spillage
(Post 3272825)
(Post 3272825)
I was just giving a point of reference, based on my experience.
It may or may not the norm, but I suspect a chain that ran without a tensioner would have less slack than that. If you're going to run a tensioner, it would be OK. |
(Post 3272832)
It may or may not the norm, but I suspect a chain that ran without a tensioner would have less slack than that. If you're going to run a tensioner, it would be OK. I don't want to run a tensioner. I don't like em, the chain tears up the tension bars. Just gets worse the more HP you push. |
Originally Posted by dodgefan99
(Post 3272833)
Sorry that that doesn't help you're current situation. The chains you have; are they specifically for a magnum, or are they LA parts? |
(Post 3272933)
I agree, that's why I don't run one.
Are your cam bearings worn? This may not help you but recently i had to do some research on roller chain. There are a lot of different manufactures with different ways of making them and tolerances/materials. I seriously doubt that the manufactures of the gear sets make their own chain. I never really though about what is used on timing chains. Anybody have a name or logo on their chains? Possibly even a #. Like to know who uses what chain. Might be able to figure out who uses a better quality chain.
