1996 V10 engine troubleshoot
Engine is dumping raw fuel into exhaust header runner on #2 cylinder. What are the possible causes? Fuel pressure is 45 PSI & injector resistance is 13.4 ohms.
Sounds just like a blown injector to me. Swap it with one of the others and see if the problem moves with it.
Is the plug firing? Does it hold psi after you shut it off or drop fast?
