Ball joint issues
Ball joint issues
I took my truck into the shop today to have some tires mounted and balanced. Well long story short when they jacked up my truck to get the wheels off the passenger side balljoints are basically falling out. They said that they feel fine and tight but aren't grabbing like suppose too. My question is, what are my next steps going to be? Should I start trying to source a new front axle or should I try another set of balljoints? For now they tack welded the balljoints in so it shouldn't drop back out but this isn't a permanent fix.
Lower balljoint
Upper balljoint
Axle seal
Lower balljoint
Upper balljoint
Axle seal
alright, would you recommend the moog problem solver or should I just replace the axle housing If the balljoints don't fit correctly?
Trending Topics
Are those 100% definitely factory ball joints? Normally the knurled ones are aftermarket, and they take a snap ring on top to prevent them from falling out. That upper however appears to be close to coming apart. The entire joint isn't falling out, the joint looks to be sloppy big time. Jack up the axle one wheel at a time, put a pry bar under the wheel and wiggle up and down while looking at the joints to verify for yourself. However, I'd just suggest replacing them all from the pics, even if they aren't "bad," then they are falling out.
