Won't run
I have 2000 dodge 1500 ram when started first time of day starts runs great. By the way 5.9 gas engine. When tried to be restarted cranks over like timing messed up, try to turn over like loaded up, if you put foot on gas pedal it will start but when you take foot of petal it dies. If I do the two foot thing and go a couple blocks it will start run it right. When shut of again same thing like timing messed up. It leaves no code told it could be crank sensor so I changed didn't fix it. Leave sit until cold fires right upturns great.
Hmm this might be better in the 2nd gen Ram section...
But have you cleaned and/or checked the throttle body? |
Moving to 2nd Gen.
Did the new Crank Sensor come from the dealership or the parts store? These trucks are kind of particular about that. How many miles on truck? Any other recent work or parts replaced?
Temp sensor
Originally Posted by Chet Ubetcha
(Post 3294050)
Moving to 2nd Gen.
Originally Posted by Craig Brabender
(Post 3294014)
(Post 3294580)
Was water temp sensor
Originally Posted by dbbd1
(Post 3294581)
Which is it, crank or water sensor that you replaced?
Great! I'm glad it got fixed. And thanks for posting the final cure.
| All times are GMT -4. The time now is 06:14 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
