Flexplate question
I have 94 Ram 5.2l with 46RH transmission. It was rebuilt and works great.
I am installing 5.9l from 96 Ram. Do I keep the 5.9L flexplate (with all the weights) or will I have to install one from the 5.2l ? There are some balancing weights on the 46RH torque converter. Thx |
Originally Posted by 94Beater
(Post 3297840)
I am installing 5.9l from 96 Ram. Do I keep the 5.9L flexplate (with all the weights) or will I have to install one from the 5.2l ? There are some balancing weights on the 46RH torque converter. Thx Use the flexplate from the 96. The weights on the torque converter are most likely to get a neutral balance...... |
1 Attachment(s)
Thanks.
I'm almost done with most of the upgrades. I should be attaching motor and transmission soon. This is just a little picture of the motor I painted Caterpillar color. Its almost there :) |
Nice!
Dang that looks great nice job
Thanks guys,
I'll make a whole post about it once I'm closer to be done It's really turning out awesome. I've painted transmission and transfer case same color. There is a lots of mods on this rig. That was nuts and it looks great |
96 flexplate wont bolt up to a 94 converter. You need to use your 94 5.2 flexplate and get a 94 5.9 converter. You're 94 5.2 converter you have now shouldn't have any weights on it. Maybe you lucked out and they gave you a 5.9 converter. Have a picture or part# of it?
3 Attachment(s)
You're right. I could not find a right pattern to bolt the two together.
However I found a weight on the side of the torque converter. Stampings on the converter are J785 2472 8377J and a sticker with number 544OHS or 644OHS first character is hard to see. Here are some pictures So all I would need is a flex plate for 1994 5.9L, right? |
That's a balance weight for the converter. I would bet that is neutral balance..... I suspect you are going to need to get a converter for a 5.9 as well. Might call around to the various parts stores\trans shops, and see if someone has one on the shelf that you can have a look at, and compare weights.
Yeah. Part number is
5440HS http://www.gopnh.com/Automotive-Part...ate%20Model%29 and it is for 3.9 and 5.2, so I will need http://www.oreillyauto.com/site/c/de...3248&ppt=C0338 for 5.9l and all should bolt in I hope :) |
