DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   No start think it's bad fuse pannel (https://dodgeforum.com/forum/2nd-gen-ram-tech/396618-no-start-think-its-bad-fuse-pannel.html)
douglassunseri Aug 4, 2016 10:50 AM
For the past week I was having to jump my 1996 dodge ram 1500 with a wire on the starter relay. Well last night I put it on a button so I can just push the button and start it. So this morning I go to try and nothing happened now my ac won't come on Windows won't go down etc... Any suggestions??
HeyYou Aug 4, 2016 10:59 AM
Ignition switch.
douglassunseri Aug 4, 2016 11:06 AM
Originally Posted by HeyYou (Post 3305830)
Ignition switch.
Wouldn't that make nothing work tho like radio and all. Everything like headlights and all come on and yesterday it was starting fine when I jumped it from the starter relay now when I try it don't do anything I have to get under it. But is that what you think it is
Friar Tuck Aug 4, 2016 11:50 AM
Things like lights that work without the ignition switch on will still work with a bad switch.
If it will not crank without your button, the switch is likely bad. If it cranked with your button yesterday, but doesn't now, the starter might be bad.
Do you have a test light or a meter?
Friar Tuck Aug 4, 2016 11:56 AM
Things like lights that work without the ignition switch on will still work with a bad switch. If it will not crank without your button, the switch is likely bad.
douglassunseri Aug 4, 2016 12:00 PM
I do have a meter I tried to check the starter relay spot in the box and couldn't get a reading but my question is why won't it jump on the starter relay now you don't think I fried the fuse exterior fuse pannel but im gonna try a ignition switch
Friar Tuck Aug 4, 2016 12:04 PM
How did you connect the button you put in last night? Are you using it to bypass the starter relay?
douglassunseri Aug 4, 2016 12:05 PM
And I can start it from the solenoid perfectly
douglassunseri Aug 4, 2016 12:06 PM
Yes that's exactly what I did just as a temporary fix
HeyYou Aug 4, 2016 12:09 PM
See if you are getting power on pin 30 of the starter relay. If not, check for burnt fuses.
© 2026 MH Sub I, LLC dba Internet Brands
