Exhaust manifold temporary fix
Old 04-17-2017, 11:30 AM
Steve Coop-aloop's Avatar
Steve Coop-aloop
Steve Coop-aloop is offline
Default Exhaust manifold temporary fix
i had to replace my exhaust manifold gaskets and of course the bolts either stripped out or were missing from previous owner. I have to order the bolts online and I currently have 4 bolts on each side, so there is quite a leak. I bought some sealer for exhaust leaks...would it do harm if I patched up the leak on the manifold with that temporarily until the bolts come in?
Old 04-17-2017, 12:18 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
If it is leaking between the manifold, and gasket, or, even out the empty bolt holes, sealer ain't gunna cut it. I wouldn't drive it like that either..... not being properly sealed will burn the gaskets, and they will never seal right. It may already be too late for them.
Welcome to DF!
Old 04-19-2017, 08:28 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
It would be fun to get that stuff off after it's hardened by the heat of the exhaust, I wouldn't use it.
Why don't you just pick up some bolts from a hardware store?
