Any difference in aftermarket fuel pump brands? Airtex goes for half the price of Denso. Delphi, carter and spectra are in between. Highest I've seen is around $210 and lowest around $100.
Don't buy Airtex unless you like changing fuel pumps. They fail after a year, or less. Denso, or Delphi are original equipment. Buy one of those. Carter? Not sure..... they used to make good stuff, I don't know today...
I have an airtex pump in my truck and it has been about a year and 2 months and fuel pressure is at 49 psi I did the test the other day.
I've heard that airtex isn't too reliable and carter was a stock one at one point but going with either Denso or Delphi. Denso is at 200 and Delphi around 160. Is it worth $200? They're all on rockauto if anyone is interested in comparing. Thanks for the responses guys!
