2002 Dodge Ram 1500 Quad Cab 5.9L won't start
Old 01-24-2018, 05:43 AM
John Brinson's Avatar
John Brinson
John Brinson is offline
Question 2002 Dodge Ram 1500 Quad Cab 5.9L won't start
Hello everyone new member to the DF and really appreciate all the information you members give out. Here's my problem I have a 2002 Dodge Ram 1500 Quad Cab 5.9L a/t 4x2 that will not start. No spark and fuel pump doesn't turn on when I cycle the key. All this happened after I replaced the transmission. The truck started up but was running rough so I left it running and went to get some gas for it when I returned 5 minutes later it was not running and hasn't been since. I have replaced the plugs,wires, rotor and cap, battery and TPS. I have read some things online about the wiring being a issue but I don't want to tear into that unless I have to and have a wiring diagram. Any help would be greatly appreciated. Thanks
I love my truck and don't want to have to get rid of it
365000 miles on original motor and when running is strong.
Old 01-24-2018, 07:49 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Probably crunched the crank position sensor while doing the trans. It's on the bell housing behind the passenger side head. Pull it, see what it looks like.
Old 01-24-2018, 08:13 AM
John Brinson
Thanks I will check it out.
Old 02-01-2018, 07:56 PM
John Brinson
So here is a update on my problem. I checked the crankshaft position sensor and the wiring was pinched between engine and transmission was worn down to the wire so I replaced it. Still have the same problem no spark, no start. I really appreciate any advice/ information anyone is willing to provide. Thank you.
Old 02-01-2018, 08:05 PM
HeyYou is offline
What brand sensor did you get? Also check the cam position sensor wiring, it's back there too, comes out of the distributor.
Old 02-04-2018, 11:50 AM
John Brinson
The brand was ultra-power. I ordered it from Rock Auto
Old 02-04-2018, 11:55 AM
John Brinson
I also replaced the fuel pump assembly at the same time. I was not getting any fuel to the rail before I replaced the crankshaft position sensor and fuel pump assembly. Now I am getting fuel to the rail but no injector pulse and no spark. I have new plugs, wires, cap, and rotor
Old 02-04-2018, 05:46 PM
HeyYou is offline
Get a crank sensor from the dealer, or, a cheaper source that sells OEM sensors, these trucks simply do not like aftermarket sensors.
Old 02-04-2018, 06:10 PM
John Brinson
Ok I'll go to the dealership and get one tomorrow. Thanks for the help
Quick Reply: 2002 Dodge Ram 1500 Quad Cab 5.9L won't start
