engine swap
Old 05-17-2018, 10:59 AM
MrMerten715's Avatar
MrMerten715
MrMerten715 is offline
Default engine swap
Is it hard to engine swap a v10 to a 5.9 cummins?
Old 05-17-2018, 11:05 AM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
No if you have the basic knowledge. You will need the Cummins PCM and engine harness. The tranny will bolt up I think. They used two transmissions I think 47RE and 48RE?. If not though you will need the tranny. The engine should bolt up if you get the mounts to. I went from a Diesel to a 360 and it was actually really simple. I'm selling a 12V auto and a 24V 6spd both have 4X,XXX miles if you are interested
Old 05-17-2018, 12:04 PM
jkeaton is offline
Dodge Forum Administrator
Is he wanting to swap a v10 into a cummins equipped truck or the other way around?
Quick Reply: engine swap
