DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   Can't find part number for this hose (https://dodgeforum.com/forum/2nd-gen-ram-tech/414556-cant-find-part-number-for-this-hose.html)
BigTunaDaBoss 05-14-2018 07:19 PM
I cut this hose to remove my power steering pump. I cut this hose so I would like to replace it but I can't seem to find it. Is it fine to reuse it if its just the hose side I cut? I have always replaced lines after doing something like this. So far I have found this but on amazon it is cheaper but it doesn't fit according to amazon. https://www.ebay.com/itm/Power-Steering-Return-Line-Hose-Assembly-Return-Line-Assembly-EDELMANN-80448/163043810584?epid=81030281&hash=item25f62b1d18:g:G-IAAOSwoDFa3ERT
https://cimg8.ibsrv.net/gimg/dodgefo...023efd9d33.jpg
xjarhead69 05-14-2018 08:22 PM
Go to Rockauto website and search for it there.
BigTunaDaBoss 05-14-2018 08:39 PM
Tried that sir, but it did not come up with the hose I need.
Shadow_Death 05-14-2018 11:17 PM
They have them on rockauto. They are under "Steering" One is "Power Steering Pressure Hose" and the other is "Power Steering Return Hose".
I've got no idea what year your truck is so I can't help with that.
BigTunaDaBoss 05-14-2018 11:58 PM
99 ram 1500 5.2. I’ve checked all rock auto but they are all the pre bent not just a flexible return line.
to point i am replacing the black hose that is cut. Not the hose above it that looks like a C
Ramman18 05-15-2018 01:19 AM
Yes, you can reuse it. I did. It's just the low pressure return line. Funny thing is it doesn't leak, but the high pressure one does.
Here's the hose:
https://www.rockauto.com/en/moreinfo...354137&jsn=425
The metal side goes to the gear, hose end to the pump.
BigTunaDaBoss 05-15-2018 09:29 AM
Is this a different hose that is installed? I swear the hose that is installed looks a lot different from the one from RockAuto.
Ramman18 05-15-2018 11:09 AM
The metal end from the pump may be different but who cares? Parts change over time and vendors change parts. Just remove it and show it to a shop if it makes you that concerned. There's only so many NTP ends and hose sizes out there. Plus they're listed as "cut to fit" anyway so just make the new line work for your truck.
2bit 05-16-2018 03:03 PM
Just go to the parts store and ask for hose suitable for power steering/ transmission fluid. They sell it by the foot. Take a piece a long so you get the right size.
BigTunaDaBoss 05-23-2018 12:58 PM
Put it on today, and everything went well, no leaks. 30 seconds later I see white smoke coming from the tailpipe and from the back of the engine bay. I think I need a new head gasket.
