Part number or description of this wiring harness to frame retainer?
Does anyone know where I can find this wiring harness to frame retainer (photos attached). This retainer holds the wiring harness for the truck's rear lights to the frame. There are 1/4" holes in the frame that these retainers push into. On the other end is a twist tie made into it the retainer stud that holds the wiring harness to the frame. Does anyone know what these are called, what the part number might be and where I can find them new?https://cimg2.ibsrv.net/gimg/dodgefo...d07fe0a2f3.jpg
https://cimg0.ibsrv.net/gimg/dodgefo...b6de9909f3.jpg |
I'm seeing a lot of different options searching "wire loom routing clips"
Maybe a body shop? They would likely have something similar.
Thanks for the thoughts so far. I tried the 'wire loom routing clip' searches, but nothing so far that matched this clip/retainer.
I'm heading to the Chryslers at Carlisle, PA show tomorrow, so I'm hoping to find some there. There is a vendor with R/T Specialties that calls himself a clipologist, so I'm sure he will know what they are and if they are available. |
Those looms do look a little more complex compared to what you have there. Yours looks more like a zip tie.
Originally Posted by AtomicDog
(Post 3400828)
Originally Posted by racefan41
(Post 3400831)
Checked with several places (including R/T Specialties) at the Carlisle, PA show on Friday and no luck in finding them. If someone knows of a part number for this clip, please let me know.
if you search Amazon for "hole cable zip tie" or "push mount zip tie" there are a lot of options. (the size of the hole is important when ordering, then length doesn't matter much since you trim it)
You might have to buy 50 of them though. It is probably still less than buying one from the dealership though. I keep buying body clips or the variety packs of body clips from Amazon. I put them in an organizer and maybe I need the same thing down the road on a different vehicle. |
Originally Posted by weazel
(Post 3401033)
(Post 3401026)
