No start after motor swap 96 ram 1500
Old 11-25-2018, 04:11 PM
flyinlowgto's Avatar
flyinlowgto
flyinlowgto is offline
Default No start after motor swap 96 ram 1500
Replaced crank sensor, cam position sensor, cap and rotor and timing gears and chain
Old 11-25-2018, 04:15 PM
Torxhead's Avatar
Torxhead
Torxhead is offline
So what are you lacking, spark or fuel?
Old 11-25-2018, 06:16 PM
flyinlowgto
I’ve got spark but how do I go about checking injectors if there working my fuel pressure is 45-50 at rail and I swapped the injectors from the original motor still nothing it acts like it wants to start but no
Old 11-25-2018, 07:59 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,165 Likes on 2,919 Posts
You can rent a noid light from your local parts store. It plugs in to the injector connector, and will tell you if you are getting injector pulse.
I wonder though, on your truck, you have two temp sensors. The one wire sensor is for the gauge in the dash, the two wire sensor, the one that's fun to get to..... is for the PCM. If it isn't hooked up, pcm will think it is REALLY cold out, and DUMP gas into the cylinders..... And if it isn't REALLY cold out, it floods the engine in short order.
Old 11-25-2018, 08:10 PM
flyinlowgto
I swapped the 2 wire one out with the one off original intake still nothing and spark plugs are wet I’m getting spark I’m confused it should run it’s in time
Old 11-25-2018, 09:06 PM
You need three things for it to run, fuel and air, in the correct proportions, and spark. You have fuel, you have spark, so I am betting it has to do with how much gas you are getting.......
Also, what plugs ya got in there?
Old 11-25-2018, 09:20 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
Is the distributor properly aligned with Cylinder #1? Is the cam sensor connected to the harness?
Old 11-25-2018, 09:40 PM
flyinlowgto
New Cam sensor is plugged in and there auto light spark plugs that I took out of the old motor literally had like 40 miles on them and yes the rotor is in the 8 o clock position where #1 is at
Old 11-25-2018, 10:04 PM
Well, you are getting gas, so, the cam sensor is going its job, you are getting spark, so the crank sensor is doing its job. I would recheck the two-wire temp sensor, make sure things are copacetic there. If they are, I would plug in with a scan tool, and see what the PCM thinks is going on. (starting with engine temp.)
Old 11-25-2018, 10:45 PM
racefan41's Avatar
racefan41
racefan41 is offline
Are you sure the spark you're getting is strong? If the spark looks orange and not making a good snap sound, it may be giving you problems.
Quick Reply: No start after motor swap 96 ram 1500
