Which gear ratio for 35" tires
Old 04-14-2019, 02:49 PM
96albertaram's Avatar
96albertaram
96albertaram is offline
Originally Posted by wca_tim
If you're patient and look around, you could probably find decent used dana 60's front and rear with 4.10 gears in them for a good bit less than putting gears in your axles... you could afford to do full service on both front and rear axles, etc... and come out money ahead with stronger axles and perhaps better brakes to boot... You'd have to get 8 lug wheels...
Just a thought...
I looked into that aswell pretty pricy up here to get new axles. How much work is it to swap them over to 3/4 ton axles? The nice wheels would have to go , or get adapters which not a fan of.
  #32
Old 04-14-2019, 02:53 PM
96albertaram
[QUOTE=wca_tim;3435440]Last year, I bought a whole torched (engine, passenger compartment fire) 98 4x4 truck that had lift kit, steering and suspension upgrades for something like $800... it had 4.10 ratio Dan 60's front and rear with a posi in the rear... both axles were in good shape (as were the steering and suspension components, transmission, transfer case, aftermarket wheels, etc...) I had it towed the 50 miles home for $100, cut everything I wanted off of it in the driveway then had a local scrap guy come haul the rest away... At the time, just on craigslist, I found several complete 2nd gen axle sets within a half day drive that were 4.10 ratio and the ones that looked to have low miles and be in good shape were probably 750 to - 1.5k? Not saying it's a slam dunk or instant thing, but it's always an option...
just did a quick craigslist search and found 4 different dana 60 fronts with 4.10 gears within a 4-5 hour drive of here... most were $600 each...[/QUOTE
Thats very intrestng i really would like to do somethng like that but harder to come by up here and they want lie 1800 per axle . Im gonna just see what happens until i can afford another solution. Its not a daily driver
  #33
Old 04-14-2019, 04:57 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
[QUOTE=96albertaram;3435463]
For that kind of money, you could buy NEW axles.......
  #34
Old 04-14-2019, 05:54 PM
96albertaram
The real question is how long is my tranny going to last running those tires with 3.55 gears?
I just installed a deep pan. Looking into the trans cooler next
  #35
Old 04-14-2019, 05:56 PM
96albertaram
[QUOTE=HeyYou;3435470]
Ya things cost more up here in canada lol
  #36
Old 04-14-2019, 08:29 PM
HeyYou is offline
Keep the trans cool, and you should be OK. External cooler is a good idea. Temp gauge wouldn't hurt either.
  #37
Old 04-14-2019, 10:45 PM
96albertaram
What is best way to run the coolers? By pass or after it comes out the rad?
  #38
Old 04-14-2019, 11:32 PM
00t444e's Avatar
00t444e
00t444e is offline
I always plumb the cooler in line after the radiator.
  #39
Old 04-15-2019, 08:08 AM
96albertaram
Right on! Thats the way i want to go.
  #40
Old 04-15-2019, 08:16 AM
wca_tim's Avatar
wca_tim
wca_tim is offline
Why after I wonder? (unless running thermostatted...). I was under the impression (but have never checked personally with measurements) that the radiator cooler would serve to warm the fluid and help maintain a constant temp when it was cold out and so should be last before going back to the engine? Of course it wouldn't matter if you were running a good thermostatted bypass...
Quick Reply: Which gear ratio for 35" tires
