Rear Differential vibration friction reducer additive?
Has anyone used friction reducer additive in their rear differential on 2nd Gen Ram 1500 4x4's to eliminate slight vibration from rear differential when turning while taking off from stopped position? I have heard this works, so want to try it versus having a dealer charge me hundreds to check it out.
Originally Posted by 19992ndGen
(Post 3439251)
It probably does have an LSD rear, friction modifier would help if the clutches are what's causing the vibration.
Originally Posted by 00t444e
(Post 3439260)
If you haven't changed the gear oil in a while I would recommend draining it and adding new fluid.
(Post 3439263)
I'd you just recently changed it, just add the additive to the gear oil. |
