So what is this vac component
The block on my 2000 1500 5.2 rusted out and, I blew a head gasket so I bought a wrecking yard motor that I put a new timing set in, rod bearings and oil pump. I just noticed this component on the wrecking yard motor that my original motor does not have on it. What is it, do I need it to pass CA smog?
thanks! https://cimg6.ibsrv.net/gimg/dodgefo...d56515a2b5.jpg |
Purge solenoid. On later engines it's mounted to the passenger fender.
Originally Posted by Ramman18
(Post 3442143)
I'm not sure where it was mounted or if it was even used on older engines. It may have been stuck there from the crew that removed the engine because that location would be tight under the firewall if factory. But the engine also has the pre-98 vent on the valve cover.
I've only seen them on the fender under the intake tube. It probably doesn't matter where you mount it, but on the engine is weird. And you'll need a rubber tube from the red cap to the airbox when fitted. |
