5 inch lift questions
Hello! I recently purchased an '01 Ram 1500 4wd for my 19th birthday. I am looking into the Rough Country 5 inch lift kit to pair with 35s. I love the way this setup looks. My truck has the 5.2L engine and I'm just wondering if I would be able to use 35s with the 5.2. I don't, and almost certainly won't, be towing anything. I mainly use the truck for hauling and as DD. I was also wondering what options I have instead of adding a block rough country gives me in the rear. I've seen somewhere that i can use an AAL part. What exactly would I need?
Thanks for all your help!! |
Originally Posted by itsfusion
(Post 3442440)
Naturally when going to bigger tires you should also change the gearing (ring and pinion).
(Post 3442440)
Put 4.56 gears in the axles and it will be fine.
Thank you, I love the stance of your truck! Is it stock wheel offset/backspacing? And I've opted to go with the upgraded gearing. Thanks for your help!
(Post 3442799)
Originally Posted by BrandonBuc'em
(Post 3442617)
i run 295/75/16 on mine and it is terrible, pretty have to drive with overdrive off anything under 50 mph. up hills is a struggle. that tire size is just about a 33 inch tire. i couldnt imagine running 35 inch tires on stock gearing. hope this helps
(Post 3442804)
Who are you taking to? You can quote them so they see the comment
(Post 3442806)
Oh goodness, I thought a quick reply to a post would auto quote it. Thanks for letting me know
