Transmission oil and cooler line change, now not shifting. Do I need to bleed air ou
Performed oil change, filter change and replaced cooler lines. Now it is not shifting. Working good before the oil change. Could there be air in the system?? If so how do I bleed the air out??
No it doesn't need to be bled. It's reading full on the dip stick while in Neutral? The lines got switched? Pressure is in the front and return is towards the back?https://dodgeforum.com/forum/attachm...y-drawing-.png
Did you check fluid level in neutral? Doesn't work in park.
