Need some help. Blower motor cuts off with acceleration.
Just got a 99 dodge ram 1500 5.2L. When I am idling the blower motor works great on every setting. However, when I am driving down the road and I accelerate the blower motor cuts off until I let off of the gas, and then blows until the next acceleration. Never had this issue before. This is my first dodge and I wondered if anyone else has had this issue. Thanks.
Are you sure it's not just switching to the defroster vents? That's a more common problem.
I haven't checked to feel but I believe it's just cutting off. When it's on the highest setting I can hear it blowing pretty well but when it happens I hear absolutely nothing from the blower.
You could run a voltmeter to the blower fuse, then try your test to see if your are loosing voltage. At least it would be a place to begin at.
(Post 3445406)
Originally Posted by Christopher Krane
(Post 3445425)
I stand corrected. Yes, it seems to switch over simply to defroster vents and weakens in force. What might be the cause of this problem? Vaccuum perhaps?
Several threads about it in the FAQ section. Including part numbers. :D
(Post 3445427)
Yes vacuum. Either a bad hose (unlikely) or a bad check valve (99.99% of the time). NAPA sells the right ones but I don't know the part#
(Post 3445452)
Look for "Wild Vents". :)
