DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   98 SS/T won't start (https://dodgeforum.com/forum/2nd-gen-ram-tech/424974-98-ss-t-wont-start.html)
jopar Aug 2, 2019 05:04 PM
98 SS/T won't start
over amped battery while trying to start now no fuel pump buzz sound,horn or spark
MoparFanatic21 Aug 2, 2019 06:46 PM
Did you check the fuses and relays?
jopar Aug 3, 2019 09:18 AM
yes they all check out as good
MoparFanatic21 Aug 3, 2019 10:56 AM
Then more then likely you fried the fuel pump, horn, and probably the crank sensor. Check to see if you are getting power back to the fuel pump.
HeyYou Aug 3, 2019 02:44 PM
How did you 'over amp' the battery??
Moparite Aug 5, 2019 08:53 AM
Over amped or over voltage? Also if the polarity was reversed you fried the pcm.
© 2026 MH Sub I, LLC dba Internet Brands
